pasan
Feb 20, 2017Aspirant
FTP user authenticated access issues - Error code 15002040001
I have enabled FTP access on 2 of my file shares with access permissions Everyone, admin +RW. My understanding is this will allow only authenticated users to access the shares via FTP. How...
- Mar 02, 2017
Checked the logs, the only clue found is the error log "cannot enable dlna when no volume exists", I am thinking if there are some settings about ReadyDLNA block the operation. Can you try disable ReadyDLNA firstly ? Then try to edit FTP settings.
pasan
Feb 22, 2017Aspirant
Hi FramerV,
I have emailed my system logs as per the linked instructions.
Hope the subject matter expert can explain the cause of this issue and a solution that won't involve resetting the ReadyNAS and deleting all data on it.
Thanks.
FramerV
Feb 24, 2017NETGEAR Employee Retired
Hi pasan,
Let me have it checked.
