ifixidevices
Jan 28, 2016Luminary
Moved drives from Pro 6 to Ultra 6 in same order, volume now missing
I thought if you had the same firmware installed on an intel unit you could move from a pro 6 to an ultra 6 as long as you kept the disks in the same order. I did just that and upon boot up it says r...
mdgm-ntgr
Jan 28, 2016NETGEAR Employee Retired
It means the SATA controller on the ReadyNAS was unable to communicate with the hard drive.
ifixidevices
Oh ok... well that's from months ago during the 6.4.1 debacle... it happened right after the drive was installed and related to that I believe.
Also the drive doesn't show any reallocated or pending sectors when looking at it's status. So it's odd the logs showed that.
