Rubatoguy
Dec 27, 2013Aspirant
NV+ will not boot - LED flashes
Hello, I have an NV+ with 4 2TB drives. The unit was not responding and the message on the front panel was "Spinning down..." but this remained on for over 20 minutes. I removed power and tried to res...
Rubatoguy
Dec 28, 2013Aspirant
So, I put the drive back in, and (BTW I have an NV+ V1) and tried accessing the boot menu with the reset - got a very strange result. At no time did the bottom LCD light up. The power button flashed rapidly, and all the leds blinked once after about 20 seconds, then after another 10 seconds or so just the LEDs above disk 2 and 4 lit up and stayed lit. No change for the next 30+ seconds. So, I turned off the NV+, restarted it and it is now booting. All disk lights are on, the power button is plusing, and the LCD menu on the bottom says "Booting, check FS x%"  I can also see the unit on RAIDar.
Hopefully, this will get it back up and running, but I want to know what checks I should do to make sure the unit is okay.
Once I get the unit up, I plan to back up all the data first thing before anything else happens.
Todd
Todd
