scottonaharley
Dec 06, 2017Aspirant
PSU not detected after upgrade to FW 6.9.1
After upgrading to FW version 6.9.1 from 6.8.x i see log messages that indicate PSU1 not detected and PSU2 not detected. The unit is populated with 12 4TB drives. I've attempted to upload the logs ...
- Jan 31, 2018
This past weekend I was able to shut down the unit, remove the power cords, remove the power supplies, release the drives from each slot and blow out any dust (there was no visible dust inside the unit and while compressed air was blowing there was no visible dust being displaced) and clean any dirt from the contacts on the back of the power supplies (there was no visible difference after cleaning the contacts.
The unit was reassembled and powered up. Since 6.9.2 had been downloaded it was installed as the machine rebooted.
Upon accessing the GUI the power supplies were both shown as installed and functioning.
While the problem is solved I'm not 100% sure that dirt was the problem and the reappearance of the power supplies could be associated with the extended amount of time the unit was powered down.
scottonaharley
Feb 01, 2018Aspirant
There is one other observation I made while the unit was disassembled. When I cleaned the power supply connector (I used an electronic contact cleaner spray which I applied to a cotton swab. Then I used the swap to clean the contact surface) I noticed that while there was little or no indication of dirt on the swab there were marks on the power supply contact surface which I presume to be from the connector on the back plane. While it wouldn’t be unusual to see those marks where there is metal to metal contact, I did notice that rather than being centered on each of the power supply contact surfaces the marks were right on the edge.
Perhaps the issue is related to the alignment of the back plane receptacle for the power supply to the connector on the power supply?
Since there were no code changes (per your earlier post) to the power monitoring function before the problem or after it was resolved. It points to a mechanical issue (the physical connection) with the root cause being either dirt, oxidation of the contacts or physical alignment of the contacts.
c3po
Feb 01, 2018NETGEAR Expert
Thanks for your inputs! Should this issue happen again on any other RN4220/3220, I will ask our tech support to debug if it is caused by dirt, oxidization or misalignment. It has to be one of these three possible causes.
PSU has its own backplane in PSU chamber, if it is caused my misalignment, I imagine that swap two PSU (or pull offending PSU )may get one or both PSU back.
We will try to isolate if it is caused by hard drive backplane or PSU backplane first. Then pin down root cause so that we can know how to solve it or prevent it.
