akustikbuero
Oct 15, 2015Star
pure performace and connecting losses after update to V 6.4.0 on RN 2120
After automatic update to V 6.4.0 our RN 2120 v2 performace is really pure. SMB-Connections to Windows 7 Clints are not stable and User/Group rights a ignored. We need a fast hotfix for those probl...
EKroboter
Oct 19, 2015Apprentice
Via SSH. If you have it enabled, you can root into it via ssh and do:
btrfs balance cancel /data
Were /data is the path to your volume.
Mine was completly locked up, so I pulled the plug and restarted. The first thing I did was cancel the balance, waited a while and everything came back online.
akustikbuero
Oct 19, 2015Star
Sh... SSH is disabled by default and I can't connect via SSH... that a pain :-(
- EKroboterOct 19, 2015Apprentice
You can try a hard reboot, and see if you can enter the web ui quick enough, you may have a couple of minutes to enable ssh before it locks up.
- akustikbueroOct 20, 2015Star
Hello again,
I tryed to reinstall the OS -> no data loss but no improvments to pure performance!
I send so much time to sort out problems, those I'm not caused! Now I'm asking: How is goning to pay me for that time?
Now I was doing a total RESET to default to get back on my real job! I hope the READYNAS will be OK after synchronizing (wipe out) the harddiscs to start from scratch... :-(
When I'll copy all data back from backup to Readynas. When it fail again I have to buy something else.
Good luck to everybody, how is having a backup!
will by continued...
Andreas
- JennCOct 20, 2015NETGEAR Employee Retired
Hello akustikbuero,
Can you please try contacting support center again before doing the reset? Inform support expert the steps you have already tried. It should be escalated then.
- akustikbueroOct 21, 2015Star
JennC: Sorry but I have a real Job to do and this ReadyNas is just a thing to work with as a fileserver. I tryed chatting with support and I tryed calling the support and lost over a weeks time.
My ReadyNAS is working perfect now and this RESET to factory default took me just 2 days. All harddrives are new formated und everything seems ok.
My tip is: BACKUP your data! :-)
Regards
Andreas
