pofrani
Apr 27, 2012Aspirant
Question about resetting
Hi all, I want to know - I have a readynas duo with 2x 1tb seagate drives. I have read that if I pressed the reset button on the back for more than 10seconds, it will do a complete factory reset (...
dbott67
Apr 27, 2012Guide
StephenB wrote: If you restore the config before re-installing the add-ons, you usually have some installation failures (which require going back to the factory reset to fix).
Good catch! 8)
