davor242
Feb 20, 2018Aspirant
Readynas 204 - v6.9.2 - Read only
It seems my RN204 decided to put shares into Ready Only mode. How do I find out why, and how do I fix it? Found this in dmesg.log: [Tue Feb 20 16:58:20 2018] BTRFS error (device md127): paren...
davor242
Feb 23, 2018Aspirant
Update: I got an external drive and did a backup (via PC).
* There is some data corruption unfortunatelly.
* Also the snapshots on one of the two shares, unfortunatelly the important one, are borked. They are sort of listed but when I open one it just opens the list of snapshots again.
* There are inconsistencies in the web UI. It says system is healthy, it says 0 snapshots in one place but a lot of snapshots in other place.
* I suspect that things went bad when I deleted a iSCSI LUN, possibly specifically when volume was rebalanced. iSCSI in itself has caused me lot of pain and tears with ReadyNAS. :/ Not touching iSCSI on ReadyNAS again.
* Currently scrubbing to see if any luck with the corrupt data.
* I have no idea how to remove the read-only stuff and try btrfs repairs.
atz6975
Mar 01, 2018Guide
Hi same status on 6.9.2 aswell. My btrfs mounts are read only.
I ssh into the system and the data is readable through SCP/SFTP/SSH. Volume capacity is 100% FREE in Readynas OS Web ui.
I've run a btrfs check --init-extent-tree on /dev/md127.
I can deal with backuping the data and losing some before Factory Default...But I wanted some adivce first.
Thanks.
Dmesg shows transid failed...
[ 18.807227] md: md127 stopped. [ 18.809384] md: bind<sdb3> [ 18.809719] md: bind<sdc3> [ 18.810061] md: bind<sdd3> [ 18.810519] md: bind<sda3> [ 18.813000] md/raid:md127: device sda3 operational as raid disk 0 [ 18.813038] md/raid:md127: device sdd3 operational as raid disk 3 [ 18.813045] md/raid:md127: device sdc3 operational as raid disk 2 [ 18.813052] md/raid:md127: device sdb3 operational as raid disk 1 [ 18.813705] md/raid:md127: allocated 4362kB [ 18.813845] md/raid:md127: raid level 5 active with 4 out of 4 devices, algorithm 2 [ 18.813853] RAID conf printout: [ 18.813856] --- level:5 rd:4 wd:4 [ 18.813862] disk 0, o:1, dev:sda3 [ 18.813866] disk 1, o:1, dev:sdb3 [ 18.813871] disk 2, o:1, dev:sdc3 [ 18.813875] disk 3, o:1, dev:sdd3 [ 18.815156] md127: detected capacity change from 0 to 8986874216448 [ 19.073929] Adding 1046524k swap on /dev/md1. Priority:-1 extents:1 across:1046524k [ 19.170923] BTRFS: device label 758b6566:data devid 1 transid 473649 /dev/md127 [ 20.317800] BTRFS info (device md127): checking UUID tree [ 20.398973] BTRFS error (device md127): parent transid verify failed on 29458432 wanted 473646 found 473649 [ 20.435184] BTRFS error (device md127): parent transid verify failed on 29458432 wanted 473646 found 473649 [ 20.635667] BTRFS error (device md127): parent transid verify failed on 29458432 wanted 473646 found 473649 [ 20.651949] BTRFS error (device md127): parent transid verify failed on 29458432 wanted 473646 found 473649 [ 20.653226] BTRFS error (device md127): parent transid verify failed on 29458432 wanted 473646 found 473649 [ 20.654264] BTRFS error (device md127): parent transid verify failed on 29458432 wanted 473646 found 473649 [ 20.883842] BTRFS error (device md127): parent transid verify failed on 29458432 wanted 473646 found 473649 [ 20.885570] BTRFS error (device md127): parent transid verify failed on 29458432 wanted 473646 found 473649 [ 20.885603] BTRFS warning (device md127): iterating uuid_tree failed -5
[ 43.472283] ------------[ cut here ]------------ [ 43.472311] WARNING: CPU: 3 PID: 1884 at fs/btrfs/extent-tree.c:941 btrfs_lookup_extent_info+0x433/0x460() [ 43.472317] Modules linked in: vpd(PO) [ 43.472333] CPU: 3 PID: 1884 Comm: btrfs-cleaner Tainted: P O 4.4.111.x86_64.1 #1 [ 43.472340] Hardware name: NETGEAR ReadyNAS/ReadyNAS , BIOS 080016 09/20/2010 [ 43.472346] 0000000000000000 ffff88002ffefce0 ffffffff883ec0e8 0000000000000000 [ 43.472358] ffffffff88d1a2fe ffff88002ffefd18 ffffffff8806f38c ffff88003d3720a0 [ 43.472368] 0000000000000002 ffff88003a01ba10 ffff88002f7221b8 0000000000000000 [ 43.472379] Call Trace: [ 43.472394] [<ffffffff883ec0e8>] dump_stack+0x4d/0x65 [ 43.472406] [<ffffffff8806f38c>] warn_slowpath_common+0x7c/0xb0 [ 43.472415] [<ffffffff8806f475>] warn_slowpath_null+0x15/0x20 [ 43.472424] [<ffffffff882e63c3>] btrfs_lookup_extent_info+0x433/0x460 [ 43.472434] [<ffffffff882ea7ae>] btrfs_drop_snapshot+0x1fe/0x860 [ 43.472446] [<ffffffff88301200>] btrfs_clean_one_deleted_snapshot+0xb0/0x100 [ 43.472457] [<ffffffff882f8602>] cleaner_kthread+0x192/0x210 [ 43.472469] [<ffffffff882f8470>] ? btrfs_destroy_pinned_extent+0xc0/0xc0 [ 43.472481] [<ffffffff88089336>] kthread+0xe6/0x100 [ 43.472492] [<ffffffff88089250>] ? kthread_create_on_node+0x170/0x170 [ 43.472504] [<ffffffff88a726df>] ret_from_fork+0x3f/0x70 [ 43.472515] [<ffffffff88089250>] ? kthread_create_on_node+0x170/0x170 [ 43.472523] ---[ end trace 58c64bad13bfb6d3 ]--- [ 43.579794] ------------[ cut here ]------------ [ 43.581016] kernel BUG at fs/btrfs/extent-tree.c:9102!
