djrees
May 27, 2017Aspirant
ReadyNAS 204 Will not shut down fully, shows do_exit+9ec
When trying to shutdown my ReadyNAS 204 it hangs with an error of do_exit+9ec on display. The only way to recover is to disconnect the AC power cord and reconnect. I have the most current version ...
Ronnycr
Jun 08, 2018Tutor
In my case, the system was unplugged for serveral days, so it was cold, still have the issue, no IP address.
So, I hear about a power supply issue might be causing the problem, which at this time, I believe is more related to it than a temperature issue.
I don´t live in US, does any one have a number for support to call internationally (+1 (area code) xxxx-xxx : NO1 800 number), I think I need a RMA.
By the way, I can't open a case becausee I am not able to register my box, I continue to get an error when trying to do that, already send a note to customer service and they confirmed having issues with it. So, my only option is to call support....
Thanks
c3po
Jun 08, 2018NETGEAR Expert
Hi Ronnycr,
Would you please help to provide following details?
1. Did you try both upper and lower Ethernet port? Did both ports fail to get an IP address?
2. When it fails to get an IP address, did RJ45 LED on Ethernet port come on? Or no any Etehrnet LED at all?
3. When this happens, does power LED eventually become solid green? Meaning boot completed successfully but without an IP?
4. If boot finishes, you press power button two or three times depends on if LCD is on, does it initiate power off sequence, and eventually display do_exit+9ec message on LCD with system fully shutdown but fails to turn off power?
5. Anything else you felt abnormal before the system ran into problem?
Thanks!
- RonnycrJun 10, 2018Tutor
Find my answers below:
Yes, both ports and nothing. Even tried to boot up with each one, after the system is cold, and nothing, both ports fails to get IP address.
2. When it fails to get an IP address, did RJ45 LED on Ethernet port come on? Or no any Ethernet LED at all?
Yes, both ports shows a solid green light only, no other light or color is displayed. See pics. Both Ethernet shows this solid green light wheather the cable is plugged or not.
3. When this happens, does power LED eventually become solid green? Meaning boot completed successfully but without an IP? Yes, exactly, solid green light and booting is completed successfully.
Yes, what you described is exactly what happens....
5. Anything else you felt abnormal before the system ran into problem? I don't know if it is abnormal or not, really didn't pay attention to it before the problem, but the system boots up quite fast until it gets to 95%, the it takes longer time to finish, but it does finish OK. I reinstalled the OS from the boot menu, didn't fix anything. The fan sounds normal, the system temperature as I touch it, seems normal.
- c3poJun 11, 2018NETGEAR Expert
Sorry for your troubles. I will try to contact our tech support and see if they can RMA your unit, if so, you will be notified by PM. Once you received replacement unit, simply move your drives to new unit, it should come up with everything same as before. Thanks.
- RonnycrJun 12, 2018Tutor
Thanks a lot, if RMA is approved, please let me know, as the shipping address from the original shipping changed (need to confirm)
Ronny
- mdgm-ntgrJun 13, 2018NETGEAR Employee Retired
ronnycr, I understand that support is waiting on you providing your shipping details to them. Did you get their email?
- RonnycrJun 22, 2018Tutor
Yes, I got the email. I sent the information more than a week ago and unfortunately, I haven't receive any news. I don't live in USA, and I was going to take advantage of a friend traveling to US to take the box. He is leaving this comming monday, but I guess I will miss it. I had never send anything back to NETGEAR, so I am not familiar with the timing... I thought was going to be faster...
- neo3779Aug 27, 2018Aspirant
I am having the same issue, please help.
- mdgm-ntgrAug 27, 2018NETGEAR Employee RetiredDo you still see this on 6.9.4 Beta?
- Marc_VSep 02, 2018NETGEAR Employee Retired
Were you able to try to upgrade to BETA firmware?
You may want to try and let us know if you still see the same issue.
Regards - neo3779Sep 04, 2018Aspirant
I cannot even get to the Webbased UI to install the firmware.
