clinford
Jun 03, 2017Aspirant
Shares not showing on Readycloud after 6.7.4 upgrade
After the 6.7.4 upgrade the folder shares aren't showing on Readycloud and on Windows app devices say Offline. Same on two PC's on differnet Networks
Hopchen
Jun 19, 2017Prodigy
Hey clinford,
I know there was an issue some time back, with long email addresses (essentially Rcloud usernames). Is your email address longer than 30 characters?
Also, if possible try and map your NAS to a different Rcloud if you have any. Would be a good troubleshooting step. Just be careful if you leave Rcloud then Rcloud user's home folders will be gone too, so you wanna back that up first.
Cheers
clinford
Jun 19, 2017Aspirant
Hi Hopchen,
Thanks for the suggestion, yes my email is so will create another account. I will give it a try and let you know.
Regards Chris.
