Platypus69
May 15, 2017Luminary
SMB 1.0 (Given Wanna Cry)
Out of curiosity in the latest 6.7.1 firmware is SMB 1.0 disabled?
Can we control SMB so that it ONLY used 3.0 or 2.0-3.0 for example?
- May 23, 2017
The Wanna Cry issue used an attack vendor to attack Windows machines that hadn't had a security update installed. Our NAS units don't run Windows.
The latest RAIDiator 4.1.x and RAIDiator-arm uses samba 3.5.x. The latest RAIDiator-x86 4.2.x uses samba 3.6.x
Experimental SMB2 support was added in samba 3.5.x, but really you should be using a newer version of samba to use it. 3.6 isn't much newer. I'd be wanting to use newer than that. To my knowledge we don't have any plans to update samba on these old OSes.
I think SMB2 support is turned off by default on all those models.
OS6 currently uses samba 4.4.x, a much newer samba series.
I've passed on the feature request to be able to disable SMB1 support from the GUI for OS6 devices.
mdgm-ntgr
May 23, 2017NETGEAR Employee Retired
PHolder
Jun 06, 2017Aspirant
Don't be pedantic. No one suggested that ReadyNAS devices ran Windows. The issue is that the recommended fix for the WannaCry was to disable SMB 1.0 and this makes legacy ReadyNAS devices that don't support SBM 2 or greater unreachable by Windows hosts on which this advice has been followed.
- StephenBJun 06, 2017Guru - Experienced User
PHolder - can we please keep this issue to one thread?
My reply to that is on your other thread; https://community.netgear.com/t5/Using-your-ReadyNAS/Any-plans-for-Samba-fix-for-CVE-2017-7494/m-p/1297911/highlight/true#M131661
The specific fix for wannacry is to install the security patches (windows and elsewhere). That doesn't mean you shouldn't disable SMB1 if you can, since it is still vulnerable to man-in-the-middle attacks. However in my view, MITM attacks are very unlikely on home networks - though they do occur on compromised enterprise networks and over-the-internet. If you keep port 445 closed in your home router, you shouldn't see any MITM threats with SMB.
FWIW, Microsoft hasn't added SMB2 or better support to Windows XP either. And they won't.
