ChunkySocks
Sep 04, 2025Guide
sudo: unable to write to /var/lib/sudo/ts/admin: No space left on device
I've SSHed into my NAS and got this message: sudo: unable to write to /var/lib/sudo/ts/admin: No space left on device This has all seemed to start after doing some tinkering with the Logitech...
Sandshark
Sep 05, 2025Sensei - Experienced User
I fail to see anything that indicates there is a BTRFS error on /dev/md0. It's just too full. As StephenB has been telling you, you need to find and delete some of the files that are there, most likely the result of LMS. If the files are corrupted, then a BTRFS repair isn't going to fix them, but an OS re-install might. But your OS partition is far too full to try that now.
Standard Linux df on a BTRFS file system is unreliable. You need to run btrfs filesystem df /. In particular, you need to pay attention to both the data and metadata usage. As StephenB also told you, you may need to run a balance on the OS partition to reclaim metadata.
I've never used LLM, but it's clearly designed for use on a standard BTRFS-based Linux installation. I think you should stop listening to it so much. Booting to a USB system to repair the ReadyNAS file system is really a bad idea. You should be booting to tech support mode, but I see nothing that indicates you need to do that at this time.
