ado1966's avatar
ado1966
Re using WD Red 2Tb
I have a NV+ v2 with 3x 3Tb WD Red drives.
I would like to remove ONE disk and factory reset the unit to work with the remaining TWO disks.
I would then like to add the now removed WD Red 2Tb in a new 102 enclosure.
As the disk already has data on it, how can i reformat it so the new 102 unit thinks its a new factory unit and installs without a problem
Many thanks
Adrian Hughes
  • StephenB's avatar
    If you have a USB enclosure, or can connect it to a Windows machine, you can use the fast write test in WDC's Lifeguard diagnostic. Or right-click on "computer" and select "manage" Then delete the partitions from the Windows disk manager.
    If the RN102 is empty, then it might reformat the drive for you. If it doesn't, then there is a way to force the factory reset from the front panel. The procedure is in the hardware manual (pages 15-16 here: http://www.downloads.netgear.com/files/ ... pr2013.pdf)
  • Thanks ! thats perfect ! and such a quick reply ! Im impressed
ProSupport for Business
