ndpm
Sep 09, 2016Aspirant
volume data is degraded
I have a ReadyNas 314 with four 3TB western digital drives in Raid 6. I receive an message that the volume data is degraded but I don't see any error in the log with the hard drives. What I can...
mdgm-ntgr
Sep 09, 2016NETGEAR Employee Retired
Your logs (e.g. systemd-journal.log) suggest there was an I/O error with disk 2. It might be worth testing that disk.
ndpm
So turn off the NAS, remove drive from slot 2 and do a test in a computer correct? Or you have Tools inside readynas to test the 2 drive?
- mdgm-ntgrSep 09, 2016NETGEAR Employee Retired
Yes. Hook it up to a PC and test it using WD Data Lifeguard Diagnostics.
We do have a disk test boot menu option, but the disk vendor's tool is best.Btw StephenB suggested looking at disk_info.log and smart_history.log, not publicly posting them.
