smarteam's avatar
smarteam
ReadNAS dual connections- USB and Ethernet simultaneously
This question is pre purchase type of question.   I am considering the ReadyNas RND212D22-100NES, but would like to know if i can access it via the USB ports as well as the netowrk.   I will use ...
  • StephenB's avatar
    Nov 21, 2016
    smarteam wrote:
    Can the USB connection be used for access to files at all on the NAS?
    No.
    They can be used to monitor a connected UPS, and you can back up the NAS to a USB-connected drive using the web-ui backup facility.  But connecting a PC over USB won't work.
ProSupport for Business
