smarteam
Nov 14, 2016Aspirant
ReadNAS dual connections- USB and Ethernet simultaneously
This question is pre purchase type of question. I am considering the ReadyNas RND212D22-100NES, but would like to know if i can access it via the USB ports as well as the netowrk. I will use ...
smarteam
Nov 21, 2016Aspirant
Ok. The intention was to have the production backup software, backkup teh NAS as a local device as well, but it sounds like i'll have to map a drive to it and accomplish it that way.
Can the USB connection be used for access to files at all on the NAS?
Thank you,
Brad
Nov 21, 2016Guru - Experienced User
No.
They can be used to monitor a connected UPS, and you can back up the NAS to a USB-connected drive using the web-ui backup facility. But connecting a PC over USB won't work.
