Madaxus
Jun 24, 2018Aspirant
Ready NAS Duo v2 - dont see model and firmware in RAIDair
Hello,
I have huge problem with my ReadyNAS Duo v2. Everytime when i turn it on everything looks fine, but when i try to find it in my network by using RAIDar it is visable without and model and firmware. When i trying to get to admin page it shows me error (cant find the page). Both disks are tested and formated (PC shows both disk status as GOOD).
I was trying connect my NAS directly to my PC ( i set subnet 192.168.168.168) and the situation repeated. It looks like there is no firmware at all... My NAS was unused for about a year, before everything was alright.
I was also trying OS reinstall with USB Recovery Tool but it fails too.
Someone have any suggestions? I will be greatful for your support.
Product number: RND2000-200EUS
Screen in the attachement
- That screenshot shows “No Disks Detected”. If the disks are fine that suggests a hardware issue with the chassis, not a problem on the internal flash.
It’s normal for it to not show the model when in the “No Disks Detected” error state.
- mdgm-ntgrNETGEAR Employee RetiredThat screenshot shows “No Disks Detected”. If the disks are fine that suggests a hardware issue with the chassis, not a problem on the internal flash.
It’s normal for it to not show the model when in the “No Disks Detected” error state.- MadaxusAspirant
Hello mdgm,
Thank you for your answer. I was almost 100% sure it does not depends on disks hmm... I will try with two new disks today evening and check it again.
- MadaxusAspirant
That was exacly HDDs. I was sure that the system files arent located on HDDs. I guess its solved, with new hdds everything works fine :)
Thanks again for your support.
