aaron123
May 18, 2015Aspirant
Ready NAS NV+ RND4000 wont connect to internet
We just switch our modem connections and now the unit doesn't seem to connect to the internet. We originally had a Motorola modem only from AT&T and there was a cisco wireless router plugged into tha...
RX
May 18, 2015Luminary
aaron123 wrote: How do I do that? I see an option in the readynas remote advanced setting to Specify Port for Incomming Connections, protocol is TCP and port is 6300. I don't see any option to specify the IP.
You will need to open (port forward) port 6300 on your existing router and point it to the local IP address of your NAS.
Since you mentioned that you have a Netgear router, check this link as your reference guide: http://kb.netgear.com/app/answers/detai ... terface%3F
