aaron123
May 18, 2015Aspirant
Ready NAS NV+ RND4000 wont connect to internet
We just switch our modem connections and now the unit doesn't seem to connect to the internet. We originally had a Motorola modem only from AT&T and there was a cisco wireless router plugged into tha...
RX
May 18, 2015Luminary
aaron123 wrote: In the netgear router, I did add a TCP port forward, i put 6300 in for Start Port, End Port, and LAN Port. I first tried selecting the LAN device, and also the IP address. On the remote added, I went into those settings and enabled the port forwarding to 6300. On the connection settings for my user profile for readynas remote, i have the port fordwarding to 6300 setup. I still dont get the blue folder, still can't access.
To check if port 6300 is really open on your Netgear router, go to http://www.subnetonline.com/pages/netwo ... canner.php then enter 6300 on the "Enter Port to scan" field then check the small box and click "Scan Port." If it says "online/reachable" then it means that port 6300 is really opened on your Netgear router.
