aaron123
May 18, 2015Aspirant
Ready NAS NV+ RND4000 wont connect to internet
We just switch our modem connections and now the unit doesn't seem to connect to the internet. We originally had a Motorola modem only from AT&T and there was a cisco wireless router plugged into tha...
May 26, 2015Guru - Experienced User
If you are port-forwarding then you need to reserve the NAS LAN address (or make it static). This is not the same as your WAN address (which is not under your control) - so you can make the LAN address static if you wish. However, reserving the address is generally better/more manageable.
Your Netgear router should let you reserve the NAS LAN address (at least all the new ones do). What model do you have?
