mc41
Jan 22, 2017Aspirant
ReadyCLOUD not connecting
Trying to connect via readycloud. Says nas is off line which it isnt any solution ? Cheers bill
phsandmeier
Jan 30, 2017Aspirant
On my Ipad works the client fine. It only not works on windows
I need the service for work. it is scary... downtime 24 houre and more!
Jan 30, 2017Guru - Experienced User
Maybe try uninstalling/reinstalling the windows client.
There are other options that you might find more reliable (or that you can use as backup methods).
If your company has a VPN deployed, you might be able to access the NAS directly when you are using their VPN.
Other alternatives include owncloud (you can get a good app for that from https://rnxtras.com/) and ZeroTier. There's a thread on ZeroTier here: https://community.netgear.com/t5/Using-your-ReadyNAS/ZeroTier-and-the-ReadyNAS/m-p/1163028#M118703
- StephenBJan 30, 2017Guru - Experienced User
You might also note this post: https://community.netgear.com/t5/ReadyCLOUD/VPN-Disconnected/m-p/1218742/highlight/true#M6497
