johnw248
May 05, 2018Aspirant
ReadyCloud not connecting
This morning I went to check on a unit and got "Unable to connect you can only connect to units on your network". I normally just reload the page and it works, this morning it didn't work. All 8 uni...
May 06, 2018Guru - Experienced User
Are your NAS using static addresses?
If you look on the cloud page in the web UI, there should be status on both internet connectivity and readycloud connectivity. What are you seeing there?
