johnw248
May 05, 2018Aspirant
ReadyCloud not connecting
This morning I went to check on a unit and got "Unable to connect you can only connect to units on your network". I normally just reload the page and it works, this morning it didn't work. All 8 uni...
May 06, 2018Guru - Experienced User
Are your NAS using static addresses?
If you look on the cloud page in the web UI, there should be status on both internet connectivity and readycloud connectivity. What are you seeing there?
johnw248
May 06, 2018Aspirant
This is how I'm connecting with Google Chrome on Win7 on various machines
http://readycloud.netgear.com/client/index.html#page=access
In the past I could right click on a unit and choose admin page. That doesn't work now on any device on any machine.
What I did find works is to change to discovery and then the manage on the right will connect to the admin page.
Don't know where the information is you refered to. Just tried to load the page in IE and it won't even get past the "loading page" message at the top. Of course gave up on IE because of all the certificate problems originally with getting to the Netgear ReadyNAS admin page.
