CarlEdman
May 08, 2014Luminary
ReadyDLNA/MiniDLNA/UPNPAV/ReadyMedia Problems
I am running the current version--reported as 1.1.0--of the boxed-in DLNA server which comes with RAIDiator 4.2.26 on my ReadyNAS Ultra 6 Plus. Most files stream fine to a variety of UPNP devices, but I am having a problem with some that generate error messages like this in /var/log/upnp-av.log:
There is nothing wrong with these files: Other files in the same directory with the same UN*X permissions play just fine. I can play them from mounted shares on a variety of platforms using a variety of software players without problems. It is not a file size problem--some of working and failing files are above or below the 2/4 GByte limit.
Other shows, just as fine using the other methods, insist that they are audio files to the DLNA clients and will not play the video content.
Any ideas?
Would upgrading to the latest ReadyMedia from Sourceforge, which appears to be a little newer, help? If so, what is the most convenient way to get it? If needs be, I can compile it from source, but ideally there would be something easier.
Thanks!
[2014/05/08 09:30:01] metadata.c:742: warn: Opening /c/media/FILENAME.mp4 failed! [Operation not permitted]
Any ideas?
Thanks!
- StephenBGuru - Experienced UserMP4s (like most container formats) can hold a variety of compressed bitstream formats, and sometimes the details on that matters. Perhaps try a mediainfo analysis? The tool can be found here: http://www.videohelp.com/tools/MediaInfo Select the text view, and cut/paste the data into a reply (hand-editing the file name if you wish).
Also, if the file name has unusual characters, you could try a test where you simplify the name, and see if that helps. - CarlEdmanLuminaryThank you, StephenB, but I doubt that is it. All the files, both the thousands that work and the dozens that don't, are h264 video (generated by x264), AAC audio, and usually mp4s subtitles. There are no non-ASCII characters in the file names.
Below are two example mediainfo outputs of the backup of two movies for which I made backups from my DVDs/Blu-rays. Both generate consistently generate the above error in readydlna.General
Complete name : Y:\Movies\Thriller\Constantine (2005) HD.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 3.01 GiB
Duration : 2h 0mn
Overall bit rate mode : Variable
Overall bit rate : 3 567 Kbps
Movie name : Constantine
Genre : Thriller
ContentType : Short Film
Description : In a world ruled largely by logic, an eccentric private detective with a taste for the supernatural investigates an apparent suicide in this thriller based on the comic book "Hellblazer." Cast: Keanu Reeves, Rachel Weisz, Shia LaBeouf, Djimon Hounsou, Ma
Recorded date : 2005
Encoded date : UTC 2014-04-09 13:18:21
Tagged date : UTC 2014-04-09 13:20:14
Writing application : MakeMP4 3.7 on Wednesday, April 09, 2014, at 09:19:02
Cover : Yes
Comment : Rating: R;Genres: Action & Adventure, Comic Books and Superheroes, Supernatural Thrillers, Action Thrillers, Blu-ray;This movie is: Dark;Format: DVD and Blu-ray
LongDescription : In a world ruled largely by logic, an eccentric private detective with a taste for the supernatural investigates an apparent suicide in this thriller based on the comic book "Hellblazer." Cast: Keanu Reeves, Rachel Weisz, Shia LaBeouf, Djimon Hounsou, Max Baker, Pruitt Taylor Vince, Gavin Rossdale, Tilda Swinton, Peter Stormare. Director: Francis Lawrence.
HDVideo : Yes
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 0mn
Bit rate : 2 719 Kbps
Maximum bit rate : 21.6 Mbps
Width : 1 920 pixels
Height : 792 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.075
Stream size : 2.29 GiB (76%)
Title : Constantine () HD T01.out.264:lang=eng:fps=23.976023976023978 - Imported with GPAC 0.5.0-rev4065
Writing library : x264 core 142 r2409 d6b4e63
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Tagged date : UTC 2014-04-09 13:18:47
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 2h 0mn
Bit rate mode : Variable
Bit rate : 327 Kbps
Maximum bit rate : 414 Kbps
Channel(s) : 2 channels
Channel(s)_Original : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 283 MiB (9%)
Language : English
Encoded date : UTC 2014-04-09 13:18:38
Audio #2
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 0mn
Bit rate : 96.0 Kbps
Maximum bit rate : 137 Kbps
Channel positions : Front: L R
Stream size : 81.5 MiB (3%)
Language : English
Encoded date : UTC 2014-04-09 13:18:41
Audio #3
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 0mn
Bit rate : 93.9 Kbps
Maximum bit rate : 144 Kbps
Stream size : 81.2 MiB (3%)
Language : English
Encoded date : UTC 2014-04-09 13:18:43
Audio #4
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 0mn
Bit rate : 87.6 Kbps
Maximum bit rate : 98.8 Kbps
Stream size : 75.7 MiB (2%)
Language : English
Encoded date : UTC 2014-04-09 13:18:44
Text #1
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 6 066 bps
Maximum bit rate : 94.2 Kbps
Stream size : 5.24 MiB (0%)
Title : Constantine () HD T07.idx:lang=eng - Imported with GPAC 0.5.0-rev4065
Language : English
Encoded date : UTC 2014-04-09 13:18:46
Text #2
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 11.6 Kbps
Maximum bit rate : 111 Kbps
Stream size : 10.0 MiB (0%)
Title : Constantine () HD T08.idx:lang=eng - Imported with GPAC 0.5.0-rev4065
Language : English
Text #3
Format : mp4s
Codec ID : E0
Duration : 1h 59mn
Bit rate : 5 066 bps
Maximum bit rate : 4 209 Mbps
Stream size : 4.34 MiB (0%)
Title : Constantine () HD T09.idx:lang=jpn - Imported with GPAC 0.5.0-rev4065
Language : Japanese
Text #4
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 4 791 bps
Maximum bit rate : 90.5 Kbps
Stream size : 4.14 MiB (0%)
Title : Constantine () HD T10.idx:lang=fra - Imported with GPAC 0.5.0-rev4065
Language : French
Text #5
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 7 261 bps
Maximum bit rate : 107 Kbps
Stream size : 6.27 MiB (0%)
Title : Constantine () HD T11.idx:lang=deu - Imported with GPAC 0.5.0-rev4065
Language : German
Text #6
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 6 060 bps
Maximum bit rate : 91.0 Kbps
Stream size : 5.23 MiB (0%)
Title : Constantine () HD T12.idx:lang=ita - Imported with GPAC 0.5.0-rev4065
Language : Italian
Text #7
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 4 878 bps
Maximum bit rate : 106 Kbps
Stream size : 4.21 MiB (0%)
Title : Constantine () HD T13.idx:lang=spa - Imported with GPAC 0.5.0-rev4065
Language : Spanish
Text #8
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 4 979 bps
Maximum bit rate : 95.2 Kbps
Stream size : 4.30 MiB (0%)
Title : Constantine () HD T14.idx:lang=nld - Imported with GPAC 0.5.0-rev4065
Language : Dutch
Text #9
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 5 411 bps
Maximum bit rate : 101 Kbps
Stream size : 4.67 MiB (0%)
Title : Constantine () HD T15.idx:lang=spa - Imported with GPAC 0.5.0-rev4065
Language : Spanish
Text #10
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 5 150 bps
Maximum bit rate : 102 Kbps
Stream size : 4.45 MiB (0%)
Title : Constantine () HD T16.idx:lang=dan - Imported with GPAC 0.5.0-rev4065
Language : Danish
Text #11
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 4 854 bps
Maximum bit rate : 90.4 Kbps
Stream size : 4.19 MiB (0%)
Title : Constantine () HD T17.idx:lang=fin - Imported with GPAC 0.5.0-rev4065
Language : Finnish
Encoded date : UTC 2014-04-09 13:18:47
Text #12
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 5 240 bps
Maximum bit rate : 94.3 Kbps
Stream size : 4.53 MiB (0%)
Title : Constantine () HD T18.idx:lang=nor - Imported with GPAC 0.5.0-rev4065
Language : Norwegian
Text #13
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 5 338 bps
Maximum bit rate : 98.9 Kbps
Stream size : 4.61 MiB (0%)
Title : Constantine () HD T19.idx:lang=por - Imported with GPAC 0.5.0-rev4065
Language : Portuguese
Text #14
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 4 670 bps
Maximum bit rate : 95.1 Kbps
Stream size : 4.03 MiB (0%)
Title : Constantine () HD T20.idx:lang=swe - Imported with GPAC 0.5.0-rev4065
Language : Swedish
Text #15
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 71 bps
Maximum bit rate : 81.3 Kbps
Stream size : 62.5 KiB (0%)
Title : Constantine () HD T21.idx:lang=fra - Imported with GPAC 0.5.0-rev4065
Language : French
Text #16
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 93 bps
Maximum bit rate : 105 Kbps
Stream size : 82.1 KiB (0%)
Title : Constantine () HD T22.idx:lang=deu - Imported with GPAC 0.5.0-rev4065
Language : German
Text #17
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 91 bps
Maximum bit rate : 94.8 Kbps
Stream size : 80.2 KiB (0%)
Title : Constantine () HD T23.idx:lang=ita - Imported with GPAC 0.5.0-rev4065
Language : Italian
Text #18
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 103 bps
Stream size : 90.3 KiB (0%)
Title : Constantine () HD T24.idx:lang=spa - Imported with GPAC 0.5.0-rev4065
Language : Spanish
Text #19
Format : mp4s
Codec ID : E0
Duration : 1h 59mn
Bit rate : 11.7 Kbps
Stream size : 10.1 MiB (0%)
Title : Constantine () HD T25.idx:lang=jpn - Imported with GPAC 0.5.0-rev4065
Language : Japanese
Text #20
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 11.1 Kbps
Maximum bit rate : 4 207 Mbps
Stream size : 9.57 MiB (0%)
Title : Constantine () HD T26.idx:lang=jpn - Imported with GPAC 0.5.0-rev4065
Language : Japanese
Text #21
Format : mp4s
Codec ID : E0
Duration : 1h 59mn
Bit rate : 3 440 bps
Maximum bit rate : 4 210 Mbps
Stream size : 2.94 MiB (0%)
Title : Constantine () HD T27.idx:lang=jpn - Imported with GPAC 0.5.0-rev4065
Language : Japanese
Text #22
Format : mp4s
Codec ID : E0
Duration : 1h 53mn
Bit rate : 27.2 Kbps
Maximum bit rate : 4 250 Mbps
Stream size : 22.2 MiB (1%)
Title : Constantine () HD T28.idx:lang=jpn - Imported with GPAC 0.5.0-rev4065
Language : Japanese
Text #23
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 9 384 bps
Maximum bit rate : 115 Kbps
Stream size : 8.10 MiB (0%)
Title : Constantine () HD T29.idx:lang=fra - Imported with GPAC 0.5.0-rev4065
Language : French
Text #24
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 11.2 Kbps
Maximum bit rate : 108 Kbps
Stream size : 9.71 MiB (0%)
Title : Constantine () HD T30.idx:lang=deu - Imported with GPAC 0.5.0-rev4065
Language : German
Text #25
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 10.9 Kbps
Stream size : 9.45 MiB (0%)
Title : Constantine () HD T31.idx:lang=ita - Imported with GPAC 0.5.0-rev4065
Language : Italian
Text #26
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 9 739 bps
Stream size : 8.41 MiB (0%)
Title : Constantine () HD T32.idx:lang=spa - Imported with GPAC 0.5.0-rev4065
Language : Spanish
Text #27
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 10.4 Kbps
Stream size : 9.00 MiB (0%)
Title : Constantine () HD T33.idx:lang=nld - Imported with GPAC 0.5.0-rev4065
Language : Dutch
Text #28
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 9 246 bps
Stream size : 7.99 MiB (0%)
Title : Constantine () HD T34.idx:lang=dan - Imported with GPAC 0.5.0-rev4065
Language : Danish
Text #29
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 8 915 bps
Stream size : 7.70 MiB (0%)
Title : Constantine () HD T35.idx:lang=fin - Imported with GPAC 0.5.0-rev4065
Language : Finnish
Text #30
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 9 840 bps
Maximum bit rate : 104 Kbps
Stream size : 8.50 MiB (0%)
Title : Constantine () HD T36.idx:lang=nor - Imported with GPAC 0.5.0-rev4065
Text #31
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 10.7 Kbps
Stream size : 9.26 MiB (0%)
Title : Constantine () HD T37.idx:lang=por - Imported with GPAC 0.5.0-rev4065
Text #32
Format : mp4s
Codec ID : E0
Duration : 2h 0mn
Bit rate : 9 192 bps
Maximum bit rate : 93.2 Kbps
Stream size : 7.94 MiB (0%)
Title : Constantine () HD T38.idx:lang=swe - Imported with GPAC 0.5.0-rev4065
Language : Swedish
Tagged date : UTC 2014-04-09 13:18:47General
Complete name : Y:\Movies\Adventure\Gladiator (2000).mp4
Format : MPEG-4
Codec ID : isom
File size : 1.09 GiB
Duration : 2h 50mn
Overall bit rate : 909 Kbps
Movie name : Gladiator
Genre : Adventure
Description : Fans of Gladiator's original theatrical release will appreciate this extended version of the epic Ridley Scott film, packed with extra action footage and gripping dialogue. Featuring a strong supporting cast and an Oscar-winning performance from actor Rus
Recorded date : 2000
Encoded date : UTC 2010-05-21 07:34:40
Tagged date : UTC 2011-11-15 18:36:08
Cover : Yes / Yes
LongDescription : Fans of Gladiator's original theatrical release will appreciate this extended version of the epic Ridley Scott film, packed with extra action footage and gripping dialogue. Featuring a strong supporting cast and an Oscar-winning performance from actor Russell Crowe as the dauntless Roman general Maximus, this big-budget Best Picture winner became an instant classic -- and helped elevate its leading man to icon status.
Video
Format : AVC
Format settings, ReFrames : 16 frames
Codec ID : avc1
Duration : 2h 50mn
Bit rate : 702 Kbps
Maximum bit rate : 3 941 Kbps
Width : 716 pixels
Height : 368 pixels
Display aspect ratio : 2.35:1
Original display aspect ratio : 2.35:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.111
Stream size : 858 MiB (77%)
Writing library : x264 core 95 r1592 95aacc4
Encoding settings : cabac=1 / ref=16 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2010-05-21 07:36:24
Audio #1
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 50mn
Bit rate : 92.3 Kbps
Maximum bit rate : 122 Kbps
Stream size : 113 MiB (10%)
Title : English
Language : English
Encoded date : UTC 2010-05-21 07:35:54
Tagged date : UTC 2010-09-21 08:19:10
Audio #2
Format : AAC
Format profile : HE-AAC / LC
Codec ID : 40
Duration : 2h 50mn
Bit rate : 60.9 Kbps
Maximum bit rate : 80.9 Kbps
Sampling rate : 48.0 KHz / 24.0 KHz
Stream size : 74.5 MiB (7%)
Title : English - Director's Commentary
Language : English
Encoded date : UTC 2010-05-21 07:36:03
Text #1
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 1 709 bps
Maximum bit rate : 4 240 Mbps
Stream size : 2.09 MiB (0%)
Language : English
Encoded date : UTC 2010-05-21 07:36:06
Text #2
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Language : English
Encoded date : UTC 2010-05-21 07:36:13
Text #3
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 1 748 bps
Stream size : 2.14 MiB (0%)
Language : French
Text #4
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 1 749 bps
Language : French
Encoded date : UTC 2010-05-21 07:36:17
Text #5
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 1 693 bps
Stream size : 2.07 MiB (0%)
Language : Spanish
Text #6
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Language : Spanish
Encoded date : UTC 2010-05-21 07:36:19
Text #7
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 2 451 bps
Maximum bit rate : 4 261 Mbps
Stream size : 2.99 MiB (0%)
Language : English
Text #8
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Language : English
Encoded date : UTC 2010-05-21 07:36:22
Text #9
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 30 bps
Maximum bit rate : 4 001 Mbps
Stream size : 37.2 KiB (0%)
Language : French
Text #10
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 30 bps
Language : French
Text #11
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 5 190 bps
Maximum bit rate : 4 267 Mbps
Stream size : 6.34 MiB (1%)
Language : English
Text #12
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Language : English
Encoded date : UTC 2010-05-21 07:36:23
Text #13
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 4 279 bps
Language : French
Text #14
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Language : French
Encoded date : UTC 2010-05-21 07:36:24
Text #15
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Bit rate : 4 464 bps
Stream size : 5.46 MiB (0%)
Language : Spanish
Text #16
Format : mp4s
Codec ID : E0
Duration : 2h 50mn
Language : Spanish
Text #17
Format : Timed Text
Codec ID : tx3g
Duration : 2h 43mn
Bit rate : 47 bps
Stream size : 56.6 KiB (0%)
Language : English
Menu #1
00:00:00.000 : Chapter 1
00:07:13.867 : Chapter 2
00:12:50.333 : Chapter 3
00:18:44.667 : Chapter 4
00:23:29.000 : Chapter 5
00:32:57.400 : Chapter 6
00:37:33.633 : Chapter 7
00:40:49.300 : Chapter 8
00:47:30.833 : Chapter 9
00:51:33.800 : Chapter 10
00:55:42.000 : Chapter 11
01:02:18.467 : Chapter 12
01:09:53.733 : Chapter 13
01:19:04.467 : Chapter 14
01:29:17.267 : Chapter 15
01:37:06.933 : Chapter 16
01:41:30.633 : Chapter 17
01:51:53.067 : Chapter 18
01:56:30.233 : Chapter 19
02:00:37.233 : Chapter 20
02:04:35.667 : Chapter 21
02:12:12.067 : Chapter 22
02:13:25.567 : Chapter 23
02:24:07.733 : Chapter 24
02:28:40.733 : Chapter 25
02:34:12.400 : Chapter 26
02:38:34.933 : Chapter 27
02:42:48.900 : Chapter 28
02:50:47.433 : Chapter 29
Menu #2
Codec ID : text
Duration : 2h 50mn
Encoded date : UTC 2010-05-22 07:39:02
Tagged date : UTC 2010-05-22 07:39:02
Bit rate mode : VBR - StephenBGuru - Experienced User
I hear you. However, one of the challenges with DLNA (compared with CIFS or NFS access) is that both the DLNA server and the DLNA player need to understand the details of the media format. The server needs to be able to demux the container and stream, it also needs to understand adapt to what the player says it can play.CarlEdman wrote: Thank you, StephenB, but I doubt that is it. All the files, both the thousands that work and the dozens that don't, are h264 video (generated by x264), AAC audio, and usually mp4s subtitles. There are no non-ASCII characters in the file names.
This makes interop issues hard to diagnose sometimes.
Anyway, that was why I asked. Your MP4s have a lot more stuff in them than most of mine, but I am not seeing anything crazy in there. Sometimes AC3 audio shows up, and I know that can cause issues with some players, but I'm not sure about ReadyDLNA. The details of the AVC encoding are consistent with the signaled profile/level (which BTW is not always the case).
I am wondering about the isom base media - is that also showing in other files that do play?
As far as practical next steps...
(a) you could try to compare mediainfo data with some similar files that do play, and see if you can discover a signature. That of course is pretty time consuming.
(b) you could try plex (https://plex.tv/downloads), and see if that works
(c) you could try remuxing these two mp4s to MKV, and see if that resolves anything.
(d) maybe PM skywalker, and see if he has any suggestions on ReadyDLNA - including your update idea. - CarlEdmanLuminaryThanks again, StephenB, you're advice is always much appreciated, in this thread as in many others I only read. I understand that these problems are fairly common, but I'm pretty familiar with media file formats, which is why this thing which has puzzled me for years is so frustrating.
One clarification to my earlier post, is that the video files which in the DLNA clients show up as audio-only appear to be the same ones for which minidlna spits out that error message. That may be a hint, but it hasn't helped me yet.
As for your suggestions:
(a) MediaInfo on all the files doesn't show me any hint of why they don't work.
(b) I'm using Plex on some devices and that--while it has problems of its own--is fine for those devices.
(c) In the past, I've tried remuxing them as mp4s again with mp4box, without success. I could try mkv, but a bunch of my players only do mp4s.
(d) Will do. My hope is that somebody at ReadyNAS who is working on the updated minidlna will have some insight, based on the source filename and line number in the minidlna error message.
Thanks again! - CarlEdmanLuminaryJust a quick update and a solution, in case somebody is looking for it:
I contacted skywalker and he was able to track down the problem to the libavmedia library (from the ffmpeg project) which minidlna uses to examine media files. Turns out that this library, or at least the version that ships with Raidiator 4.2.X, barfs on mp4s with more than 20 streams. He has a patch that ameliorates the issue. - NasinatorAspirantIs this patch available for NV1+ Raidiator 4.1.13?
