PC1staid
May 03, 2018Aspirant
ReadyNas 102 fails to load admin page after latest firmware upgrade
system
Hi all. Got myself in a little bit of a pickle. Had my Readynas sind 2015 and apart from a few minor issues all has been working well.... till now. I recently discovered that one of my 3tb h...
JohnCM_S
May 03, 2018NETGEAR Employee Retired
Hi PC1staid,
You may try first clearing the web browser cache, then close and re-open the browser, and see if you will be to access the admin page.
- PC1staidMay 04, 2018Aspirant
JohnCM_S wrote:
Hi PC1staid,
Hi, I have tried this on all three browsers I have on my system, also I get the same results on an iMac. I have just done a clean install on a customers PC, attempted the login again with the same result on I.E. and Edge. Am I able to do a roll back via the 6.5.2 on a USB stick plugged dirrectly into the 102? I have read firmware updates can be done this way, just not sure if a downgrade can be done.
Thanks.
Marc
- mdgm-ntgrMay 04, 2018NETGEAR Employee Retired
You should not downgrade to firmware prior to 6.9.0. There is something else that should be tried before resorting to attempting to downgrade the firmware.
