GGlover24
Sep 27, 2019Aspirant
ReadyNAS 104 - Degraded Volume and Disk Test
Hi, I have a ReadyNAS 104 with four 2TB Drives. My system show degraded and I have started a Disk Test which, I assume, will take between 8-16 hrs to complete. 1. I have 4 drives in but only dri...
JohnCM_S
Sep 27, 2019NETGEAR Employee Retired
Hi GGlover24,
Welcome to the Community!
No, it is not normal that only two disks are detected.
You can remove the drives while the disk test is in progress. You need to power down the NAS first then remove the drives afterward.
You can also download the NAS system logs then provide it to us so we can check why the disks 2 and 3 are not detected. You can do that by uploading the logs to a file-sharing site then send the download link via PM (private message)
- GGlover24Sep 27, 2019Aspirant
Okay, I sent the message.
