GGlover24
Sep 27, 2019Aspirant
ReadyNAS 104 - Degraded Volume and Disk Test
Hi, I have a ReadyNAS 104 with four 2TB Drives. My system show degraded and I have started a Disk Test which, I assume, will take between 8-16 hrs to complete. 1. I have 4 drives in but only dri...
GGlover24
I am assuming that I have to order new drives as it may be that at least two of the drives has failed and the other two are dying too.
My question is should I drives matching the same Cache, in this case 64 or can I mix-n-match the Cache size?
Thanks
GG
- JohnCM_SSep 27, 2019NETGEAR Employee Retired
Hi GGlover24
Do you have a backup of your data?
I checked the kernel.logs and it is flooded with errors from disks 2 and 3.
It will be best if you connect those disks to a PC then run a diagnostic test using the disk manufacturer's tool, then replace the disks that come out bad. Factory reset the NAS then restore from backups.
If the issue still re-occurs, the issue might be on the chassis already.
- GGlover24Sep 27, 2019Aspirant
Thank you for helping me out, I appreicate it.
Can I just replace those two drives, 2 and 3 or are all the drives bad?
GG
- JohnCM_SSep 28, 2019NETGEAR Employee Retired
Hi GGlover24,
Based on the logs, only disks 2 and 3 are having errors. There are no reports of any errors on disks 1 and 4.
