GGlover24
Sep 27, 2019Aspirant
ReadyNAS 104 - Degraded Volume and Disk Test
Hi, I have a ReadyNAS 104 with four 2TB Drives. My system show degraded and I have started a Disk Test which, I assume, will take between 8-16 hrs to complete. 1. I have 4 drives in but only dri...
GGlover24
I am assuming that I have to order new drives as it may be that at least two of the drives has failed and the other two are dying too.
My question is should I drives matching the same Cache, in this case 64 or can I mix-n-match the Cache size?
Thanks
GG
JohnCM_S
Sep 27, 2019NETGEAR Employee Retired
Hi GGlover24
Do you have a backup of your data?
I checked the kernel.logs and it is flooded with errors from disks 2 and 3.
It will be best if you connect those disks to a PC then run a diagnostic test using the disk manufacturer's tool, then replace the disks that come out bad. Factory reset the NAS then restore from backups.
If the issue still re-occurs, the issue might be on the chassis already.
- GGlover24Sep 27, 2019Aspirant
Thank you for helping me out, I appreicate it.
Can I just replace those two drives, 2 and 3 or are all the drives bad?
GG
- JohnCM_SSep 28, 2019NETGEAR Employee Retired
Hi GGlover24,
Based on the logs, only disks 2 and 3 are having errors. There are no reports of any errors on disks 1 and 4.
Regards,- JohnCM_SOct 01, 2019NETGEAR Employee Retired
Hi GGlover24,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
