blacky1
Jan 09, 2015Tutor
ReadyNAS 104 - SMB Shares randomly disconnect from OS X Yose
Hi Ever since upgrading to OS X 10.10 all mounted shares from the ready NAS over SMB randomly disconnect making working on the NAS a nightmare. I've since upgraded to OS X 10.10.1 and upgraded yest...
blacky1
Jan 13, 2015Tutor
Update:
Earlier, I tested mounting one NAS share (Archived_Jobs) using the Finder and another NAS share (Active_Jobs) using Terminal:
Later, looking at Console I see this:
This time I see that only the share mounted via the Finder (Archived_Jobs) was 'force unmount'. The share mounted via Terminal (Active_Jobs) is still working!
Could this be a clue?
I'm going to try mounting all shares from the Terminal and see if I get any randomly disconnect now.
mkdir /Volumes/Active_Jobs
mount -t smbfs //<USERNAME>:<PASSWORD>@192.168.17.92/Active_Jobs /Volumes/Active_Jobs/
13/01/2015 15:36:53.644 KernelEventAgent[71]: tid 54485244 received event(s) VQ_NOTRESP (1)
13/01/2015 15:36:53.644 KernelEventAgent[71]: tid 54485244 type 'smbfs', mounted on '/Volumes/Active_Jobs', from '//nick@192.168.17.92/Active_Jobs', not responding
13/01/2015 15:36:53.644 KernelEventAgent[71]: tid 54485244 type 'smbfs', mounted on '/Volumes/Archived_Jobs', from '//nick@192.168.17.92/Archived_Jobs', not responding
13/01/2015 15:36:53.644 KernelEventAgent[71]: tid 54485244 found 2 filesystem(s) with problem(s)
13/01/2015 15:36:53.645 loginwindow[69]: Error: could not load nib file for DisconnectedFS plugin
13/01/2015 15:37:48.990 KernelEventAgent[71]: tid 54485244 received event(s) VQ_DEAD (32)
13/01/2015 15:37:48.990 KernelEventAgent[71]: tid 54485244 type 'smbfs', mounted on '/Volumes/Archived_Jobs', from '//nick@192.168.17.92/Archived_Jobs', dead
13/01/2015 15:37:48.990 KernelEventAgent[71]: tid 54485244 force unmount //nick@192.168.17.92/Archived_Jobs from /Volumes/Archived_Jobs
13/01/2015 15:37:48.990 KernelEventAgent[71]: tid 54485244 found 2 filesystem(s) with problem(s)
13/01/2015 15:38:22.136 KernelEventAgent[71]: tid 54485244 received event(s) VQ_NOTRESP (1)
13/01/2015 15:38:22.000 kernel[0]: smb_iod_reconnect: Reconnected share ACTIVE_JOBS with server 192.168.17.92
