Seanmo
May 30, 2016Aspirant
Readynas 104 disk activity led always on
Just noticed today that my disk activity light is always on. Don't think it did this before the latest firmware 6.5.0 I'm not copying any files, doing backups and the device reports that the disks a...
BrianL2
May 31, 2016NETGEAR Employee Retired
Hi Seanmo,
Welcome to the community!
Can you confirm if you have installed add-ons and enabled services that require internet from your ReadyNAS? If yes, the activity LED might be on.
Kind regards,
BrianL
NETGEAR Community Team
Seanmo
Jun 07, 2016Aspirant
Hi Brian,
Sorry for the delay replying to you. I don't have any services or apps running that I am aware of it's just for basic home use as storage really
so I'm at a loss as to why it's on all the time.
Regards
- BrianL2Jun 07, 2016NETGEAR Employee Retired
Hi Seanmo,
Can you confirm if ReadyCLOUD and other services that require the internet enabled?
Kind regards,
BrianL
- SeanmoJun 21, 2016Aspirant
Hi,
It's only Readycloud that is enabled. There don't apear to be any other services enabled. It's just a home setup on a very basic network and tight fisted as I am
with the electricity, I turn everything off when not in use. The disks spin down after 10 mins of inactivity and go to sleep and report they are asleep when the activity light is flashing on and off.
Just to clarify I don't use the readycloud that often, it's only me that uses it. Just a reminder that even with discs asleep and both ethernet cables pulled out the light still stays on:)
