Seanmo
May 30, 2016Aspirant
Readynas 104 disk activity led always on
Just noticed today that my disk activity light is always on. Don't think it did this before the latest firmware 6.5.0 I'm not copying any files, doing backups and the device reports that the disks a...
spiffin
Jul 07, 2016Aspirant
Hi Brian
Yes, okay. How do we do this?
Simon
BrendanM
Aug 12, 2016NETGEAR Expert
This has been reported to engineering internally. I will post back here when I have an update.
- booboo59Aug 13, 2016Apprentice
Add me to the list of customers with the same symptom.
- mdgm-ntgrAug 14, 2016NETGEAR Employee Retired
Engineering informed us that this is by design. If you find that LED distracting you may wish to cover it with electrical tape.
- StephenBAug 15, 2016Guru - Experienced User
You could also vote for the idea here: https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/Add-the-ability-to-Dim-the-Power-Light/idi-p/1049769
Click on the up-arrow icon to vote for it.
- mdgm-ntgrAug 15, 2016NETGEAR Employee Retired
The activity LED always being on in normal use is shown in the hardware manual.
On - At least one disk present.
Blinking - A disk is active.
Off - No disks are present.
- SeanmoAug 30, 2016Aspirant
Fair enough my mistake, I never looked at that part in the manual as I assumed it functioned the way a pc hard drive light usually does when there is disk activity.
Perhaps it's just me being overly picky (and a tad mischevious:smileyhappy:), but don't the Drive Bay LED numbers tell you if a disk is present (see from the manual below)? So it just seems a bit overkill to have the activity light on 24/7 to tell you a disk is present, when half an inch away, there are numbers 1-4 that light up if a disk is present? Anyway thanks for everyone's assistance - if this is the only issue I have with my Readynas I'll think my self very lucky it's a great little device to be fair.
Each drive bay has an LED associated with it on the front panel of the storage system. The disk LEDs have these states:
• On. Power is on and the disk is operating normally.
• Blinking. The disk was removed, failed, or is resynchronizing.
• Off. The drive bay is empty
