haigha
Dec 24, 2022Aspirant
ReadyNAS 104 No Volume Exists
Greetings: I was having an issue with my ReadyNAS 104 [see: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-104-Inaccessible-ReadyNAS-Admin-Page-is-Offline/td-p/2241534] whi...
Dec 25, 2022Guru - Experienced User
haigha wrote:
I replaced the failing drive #4 and the NAS recognized a new drive had been inserted.
I upgraded to the latest firmware (6.10.8) and rebooted to start the RAID rebuild, but the NAS is no longer seeing any volumes.
It would have been better to wait for the resync to complete before you updated the firmware and rebooted.
Do you still have an up-to-date backup?
- haighaDec 26, 2022Aspirant
I did try waiting for the new drive to rebuild, but the NAS just sat there inactive.
After a day-and-a-half, I decided to try the reboot.
I don't have a full back-up, but I was able to back up my most important files to a USB.
It's looking like I may have to create a new volume and start reloading the files I have backed up.
- StephenBDec 26, 2022Guru - Experienced User
If you decide to do that, then I suggest doing a factory default, which would rebuild everything.
You can do that either from the boot menu, or from system->setting in the NAS web ui.
Thanks for that suggestion.
I may just begin with the single 6TB drive I bought as a replacement, then add additional 6TB drives until all 4 bays are filled.I ran a diagnostics check, and it looks like my other drives are also failing.
