haigha
Dec 24, 2022Aspirant
ReadyNAS 104 No Volume Exists
Greetings: I was having an issue with my ReadyNAS 104 [see: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-104-Inaccessible-ReadyNAS-Admin-Page-is-Offline/td-p/2241534] whi...
haigha
Dec 26, 2022Aspirant
I did try waiting for the new drive to rebuild, but the NAS just sat there inactive.
After a day-and-a-half, I decided to try the reboot.
I don't have a full back-up, but I was able to back up my most important files to a USB.
It's looking like I may have to create a new volume and start reloading the files I have backed up.
Dec 26, 2022Guru - Experienced User
If you decide to do that, then I suggest doing a factory default, which would rebuild everything.
You can do that either from the boot menu, or from system->setting in the NAS web ui.
- haighaDec 26, 2022Aspirant
Thanks for that suggestion.
I may just begin with the single 6TB drive I bought as a replacement, then add additional 6TB drives until all 4 bays are filled.I ran a diagnostics check, and it looks like my other drives are also failing.
- SandsharkDec 27, 2022Sensei
That looks like it may only be Disk 2 failing. The others are for volumes that include it.
What model drive did you add? If it's a SMR model (WD Red and many desktop models), then that would be the reason for the lengthy re-sync. But it's also reason that you don't want it to be a part of your new volume.
It could be the failing drive that was causing the long re-sync, but you don't seem to have enough errors recorded to give that much trouble.
