leew87
Mar 20, 2019Aspirant
READYNAS 104 System volume root's usage error
hi
this morning i have recieved an Alert of the following
"System volume root's usage is 87%. This condition should not occur under normal conditions. Contact technical support." how do i go about resolving this?
i have read abit on line i have disabled the anti virus and any backup jobs i had that didnt run correctly. and restarted the NAS how do i clear out unused files on the System root?
thanks everyone in advanced
a detailed description how to repair the problem is posted by StephenB in message 3 of this thread https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/System-volume-root-s-usage-is-90-RN102/m-p/1723484#M178504 or you take my (not so detailed) instructions in message 3, 7 and 10 (especially jpg-attachment) of this thread https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/System-volume-root-s-usage-is-xx-Th...
- leew87Aspirant
thanks for your swift reply
i have followed the instructions is there a way i can check the s System volume root's usage has returned to normal?
the only reason i knew it has increase was a email i recieved yesterday
leew87 wrote:
is there a way i can check the System volume root's usage has returned to normal?
Log in via ssh again, and use df to tell you the space usage. For example
Welcome to ReadyNASOS 6.9.5 root@NAS:~# df // -h Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 940M 2.9G 25% / root@NAS:~#
Normally it will be about 25% used.
