szucsmiki
May 05, 2016Aspirant
Readynas 1100 Active direcrory option is not found
Hello My company uses a Redynas 1100 for long ime, it was joined the domain. It had some problem, so I did a factory reset, now it is up and running, but cannot find the option to join the domain. W...
Retired_Member
May 05, 2016Hi,
User manual page 27: http://www.downloads.netgear.com/files/GDC/RND2110/RAIDiator4-1_SW_en_06Dec11.pdf?cid=gwmng
Select a Security Mode
This procedure applies only to the ReadyNAS NV+ and 1100.
To select a security mode:
1. From the FrontView main menu, select Security > Security Mode.
2. Select either Share, User, or Domain.
- szucsmikiMay 05, 2016Aspirant
Thanks for quick answare...
I have read the article you mentioned, but there is no Security Mode option under Security menu.
I have searched for this option in the menu structure but couldn't find...
Any suggestion?
Thanks:Miki
