szucsmiki
May 05, 2016Aspirant
Readynas 1100 Active direcrory option is not found
Hello My company uses a Redynas 1100 for long ime, it was joined the domain. It had some problem, so I did a factory reset, now it is up and running, but cannot find the option to join the domain. W...
Retired_Member
May 05, 2016Hi,
User manual page 27: http://www.downloads.netgear.com/files/GDC/RND2110/RAIDiator4-1_SW_en_06Dec11.pdf?cid=gwmng
Select a Security Mode
This procedure applies only to the ReadyNAS NV+ and 1100.
To select a security mode:
1. From the FrontView main menu, select Security > Security Mode.
2. Select either Share, User, or Domain.
szucsmiki
Thanks for quick answare...
I have read the article you mentioned, but there is no Security Mode option under Security menu.
I have searched for this option in the menu structure but couldn't find...
Any suggestion?
Thanks:Miki
- StephenBMay 05, 2016Guru - Experienced User
Possibly the firmware is confused on the NAS model (treating your system like a Duo). If so, you will need Netgear support to fix it.
- szucsmikiMay 05, 2016Aspirant
It is a Readynas1100 system and support has ended...
Is it possible to downgrade the firmare?
You can still get per-incident support if you are the original purchaser - even if the warranty has expired.
szucsmiki wrote:
Is it possible to downgrade the firmare?I think this happened when you reset. I don't think downgrading the firmware will fix it, but you can try it.
What model are you seeing on the home page? Model information is stored in an EEPROM in the NAS, and it is possible that information has gotten a bit messed up.
