szucsmiki
May 05, 2016Aspirant
Readynas 1100 Active direcrory option is not found
Hello My company uses a Redynas 1100 for long ime, it was joined the domain. It had some problem, so I did a factory reset, now it is up and running, but cannot find the option to join the domain. W...
szucsmiki
Thanks for quick answare...
I have read the article you mentioned, but there is no Security Mode option under Security menu.
I have searched for this option in the menu structure but couldn't find...
Any suggestion?
Thanks:Miki
May 05, 2016Guru - Experienced User
Possibly the firmware is confused on the NAS model (treating your system like a Duo). If so, you will need Netgear support to fix it.
