tgoecks
Nov 13, 2014Aspirant
ReadyNas 1100 can't connect --PLEASE HELP--
Our company has a ReadyNAs 1100 that's used to store data temporary. For whatever reason we cant seem to find the IP address or get it to grab an IP address. Both NIC's light up on the back and on the...
Nhellie
Nov 28, 2014Virtuoso
You can connect the NAS directly to a PC and assign a static IP 192.168.168.x (the default IP of the NAS is 192.168.168.168. so you should assign an IP on its range). Check it on raidar or try to ping the IP (192.168.168.168) if it responds, try accessing it using a browser.
If there is a static IP assigned on the NAS, you have to perform an OS reinstall.
