davor242
Feb 20, 2018Aspirant
Readynas 204 - v6.9.2 - Read only
It seems my RN204 decided to put shares into Ready Only mode. How do I find out why, and how do I fix it? Found this in dmesg.log: [Tue Feb 20 16:58:20 2018] BTRFS error (device md127): paren...
mdgm-ntgr
Feb 28, 2018NETGEAR Employee Retired
atz6975 wrote:
I've run a btrfs check --init-extent-tree on /dev/md127.
Why? If there is corruption that can bake it in.
atz6975
Feb 28, 2018Guide
Indeed...I got lucky it didn't do much.
Any thoughts on next step (beside wiping device)?
- mdgm-ntgrFeb 28, 2018NETGEAR Employee Retired
Have you tried using btrfs restore to see if you can restore a copy of the data e.g. onto a USB disk?
- atz6975Feb 28, 2018Guide
Thx for you concern Mdgm.
Yes btrfs restore works, and the volume is actually mounted (read-only) by readynas OS anyway.
So accessing the data is not looking too hard.
I just hoped to save the snapshots and avoid rebuilding and back and forth of data (6TB out and back in).
As I type this, the NAS has become unresponsive remotly, so I'll go on-site have a look and probably cold reboot. It seems Frontview is bringing it down trying to access some info (in my case Backup jobs definition).
