djrees
May 27, 2017Aspirant
ReadyNAS 204 Will not shut down fully, shows do_exit+9ec
When trying to shutdown my ReadyNAS 204 it hangs with an error of do_exit+9ec on display. The only way to recover is to disconnect the AC power cord and reconnect. I have the most current version ...
djrees
Jun 03, 2017Aspirant
Logs sent as requested. Let me know if you need any other information.
Thank you,
Skywalker
Jun 05, 2017NETGEAR Expert
Do you have anything plugged in to the LAN 2 port?
- djreesJun 05, 2017Aspirant
Yes, have cables in both LAN ports. This problem occurs even with just one LAN port is connected and with bonding off. Ijust set up LACP this weekend on my switch and NAS. Works ok for a short while. Then the top LAN port goes dead on the NAS. Have tried different patch cords, different switch ports on switch. Troubleshooting always leads back to the NAS as the problem. I just discovered the top LAN port problem this weekend.
- IlSelNov 03, 2017Aspirant
Has this issue actually been ever root caused or resolved? I'm now on 6.9 and am experiencing this very same issue. Restart works, but shutdown leads to do_exit_9ec message.
- SkywalkerNov 03, 2017NETGEAR Expert
There was an issue that was located back in April, where if you had WoL enabled and a WoL magic packet came in while the box was running, it would prevent shutdown. That's the only shutdown failure that we've been able to reproduce and debug.
If you're seeing issues where you're unable to shut down on 6.9.0, please describe your network, WoL, and power timer configuration.
