djrees
May 27, 2017Aspirant
ReadyNAS 204 Will not shut down fully, shows do_exit+9ec
When trying to shutdown my ReadyNAS 204 it hangs with an error of do_exit+9ec on display. The only way to recover is to disconnect the AC power cord and reconnect. I have the most current version ...
Ronnycr
Jun 04, 2018Tutor
Hi I do have the exact same problem, RN214 with No IP, Nic do not work, and got the exact same message: do_exit+9ec. I also got version 6.9.3.
Have you get any update/solution from your case? My RN214 is a brick right now and I am really worry about my data. Thanks.
djrees
Jun 04, 2018Aspirant
Since I started this thread I felt I should put in my experience. This may or may not be related to the reason that your NAS shows this error.
In my case the problem was related to one of the NIC going bad. My unit was still under warranty and was exchanged. Replacement unit is working without a problem.
