ifubesi
May 26, 2023Aspirant
ReadyNAS 212 drops second drive
I've got a ReadyNAS 212 with a couple of WD Red 4tb drives in it. If you even look at this thing sideways, it will act like the second drive is not there. It takes several restarts and reseating of...
May 26, 2023Guru - Experienced User
ifubesi wrote:
Anytime I get a blip in power, I have to go through this dance again.
One thought is to get a UPS
ifubesi wrote:
I don't see anything odd in the logs.
You might try using smartctl -x via ssh. Maybe also try running the disk test from the volume settings tab.
FWIW, I haven't seen this issue with my own RN202 - though it is running two jbod volumes,and not RAID-1. Currently a 14 TB Exos disk and a 14 TB WD Red Plus are installed.
