rph1
Jul 22, 2015Star
ReadyNAS 2120 Admin Web Interface - Device Offline
I have a ReadyNAS 2120 on firmware 6.2.2 that is currently reports as being offline when I try to access the administrative web interface. It does get me logged in but presents the dialog box saying ...
rph1
Jul 22, 2015Star
Thanks for the replies. So I am guessing by the responses there is no other way than those I have already tried to gracefully shutdown/restart the 2120 and all I am left with is another power reset?
As for upgrading the firmware, the latest version it tells me is available is 6.2.4, not 6.2.5RC. Where would I get that version from and is it applicable to my ReadyNAS 2120?
Thanks.
mdgm-ntgr
Jul 22, 2015NETGEAR Employee Retired
Will send you a PM on the first point.
For 6.2.5 see https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-2-5-RC1/m-p/950451#U950451
- sg86Aug 01, 2015Aspirant
Why PM? I am (since today only) having this same issue. I'm on 6.2.4 and everything outlined applies to me.
What are my options regarding powering down etc, i don't see the reason for PM'ing this to the OP when others can benefit from the information.
- mdgm-ntgrAug 02, 2015NETGEAR Employee Retired
Steps to see if remote access to look into this can be enabled are only suitable for sharing on a case by case basis.
I will send you a PM. - rph1Aug 02, 2015Star
Basically, I was unable to perform a graceful shutdown myself with any of the methods currently available so mdgm sent me a pm message so we could discuss his obtaining remote access to my unit to attempt a graceful reboot, which he was able to complete.
My firmware was only on 6.2.2 and as part of the process it was upgraded to 6.2.4. It is too early to tell if that has resolved my problem because it takes a while for the situation to occur. Its troublesome to hear you are already on 6.2.4 and having the same issue I did. That means there is a chance upgrading the firmware will not resolve my issue either. Only time will tell though.
Good luck with getting your system rebooted.
The issue sg86 is facing may have a different cause. One would ned to have a look to see what's going on.
Seeing the system is on 6.2.4 the logs may be able to be downloaded using RAIDar 6.0 then emailed in (see the Sending Logs link in my sig).
