Alein
Sep 22, 2016Aspirant
ReadyNAS 2120 V2 hangs alost every month and LUN connection problem
Hi , I have some problem with this hardware.
1.Sometimes my ESXi reboot, and LUNs are not able to reconnect. I see that, when I will try reboot NAS, I am warn that there are still active LUNs....
- Dec 13, 2016
It seems that iSCSI is useless on this devices.
Since I had removed whole iSCSI configuration, my NAS become much more stable, even with snapshots and NFS datastore for ESXi.So my recomendation, Disable iSCSI.
mdgm-ntgr
Oct 05, 2016NETGEAR Employee Retired
Well redo your setup but this time do it per the recommendations I gave above and see if you still have issues.
Alein
Oct 08, 2016Aspirant
Well,
I made upgrade to OS 6.6 and my NAS died :( There is no ping, he is not trying to get IP, Reinstal OS is not helping.RAIDAR is not detecting it.
Any idea what can I do? I can not downgrade as this is new Debian and there is such information.
- StephenBOct 08, 2016Guru - Experienced User
You might need to use netgear (paid) support.
- AleinOct 11, 2016Aspirant
It is really buggy FW.
After upgrade my LAG was reconfigured to default settings.
Now I have issue with NFS41
vmware is telling me that it is not supported :(
WARNING: NFS41: NFS41ExidPathProcess:2095: Server doesn't support the NFS 4.1 SunRPC program
- AleinDec 13, 2016Aspirant
