TCHol95
Jun 08, 2016Guide
ReadyNAS 2120 will not sync with AD - Time offset too large
ReadyNAS 2120 stopped syncing with AD. Firmware is 6.5. Error is "Time off set between this system and ADS server is too large", but there is no time difference.
comando
Jun 08, 2016Aspirant
Hello list, I have the same problem, when I upgrade the fireware the Ready Nas do not sync with AD, I have a temporal solution.
1- cd /var/readynasd
2- systemctl stop readynasd
3- rm db.sq3
4- net cache flush
5 sqlite3 /var/readynasd/db.sq3 'delete from "$home_folder";'
6- systemctl start readynasd
And everything is ok, I can reboot the system and all is ok, but but, I think the ReadyNas try to sync every 12 hours, because when I loging in the web tomorrow for exmple, back the problem again, and I have to repeat the step.
Definitly somebody have a solution for this problem.........Is not easy repeat the steps every day
TCHol95
Jun 08, 2016Guide
For some reason mine started allowing access, but it still won't sync with AD, or at least the error is saying it won't. I'll have to give your workaround a try. I find as a rule these ReadyNAS units sometimes don't eagerly sync with AD. Out of all of them I've set up only one has does a sync with AD without issue.
- comandoJun 08, 2016Aspirant
but there must be a solution, it is not easy every day to run the procedure
