TCHol95
Jun 08, 2016Guide
ReadyNAS 2120 will not sync with AD - Time offset too large
ReadyNAS 2120 stopped syncing with AD. Firmware is 6.5. Error is "Time off set between this system and ADS server is too large", but there is no time difference.
TCHol95
Jun 08, 2016Guide
For some reason mine started allowing access, but it still won't sync with AD, or at least the error is saying it won't. I'll have to give your workaround a try. I find as a rule these ReadyNAS units sometimes don't eagerly sync with AD. Out of all of them I've set up only one has does a sync with AD without issue.
comando
Jun 08, 2016Aspirant
but there must be a solution, it is not easy every day to run the procedure
- SandsharkJun 09, 2016Sensei
Do you have the time zone set correctly on the NAS? Maybe it somehow got changed with OS update?
- TCHol95Jun 09, 2016Guide
Yes, the time zone is correct. I just checked it and for whatever reason it's syncing without issue. I changed nothing since the issue started.
- comandoJun 10, 2016Aspirant
Hello list, continuing with the problems of my NAS that does not synchronize users with active directory, is there any way to tell the NAS try not automatically synchronize at night because I have a temporary solution, but when you try to synchronize by night turns to lose everything and then you have to re-run all the steps.
