TCHol95
Jun 08, 2016Guide
ReadyNAS 2120 will not sync with AD - Time offset too large
ReadyNAS 2120 stopped syncing with AD. Firmware is 6.5. Error is "Time off set between this system and ADS server is too large", but there is no time difference.
TCHol95
Jun 10, 2016Guide
Yes, the time zone is correct. I just checked it and for whatever reason it's syncing without issue. I changed nothing since the issue started.
comando
Jun 10, 2016Aspirant
Hello list, continuing with the problems of my NAS that does not synchronize users with active directory, is there any way to tell the NAS try not automatically synchronize at night because I have a temporary solution, but when you try to synchronize by night turns to lose everything and then you have to re-run all the steps.
