Coolfeather2
Jan 01, 2017Aspirant
Readynas 214 Remote Connection without ReadyCloud?
Wondering if its possible to remote connect to the nas on windows and linux OS for when I go to tafe this year and need to backup files
FramerV
Jan 01, 2017NETGEAR Employee Retired
Hi Coolfeather2,
Welcome to the community.
You could consider using FTP or HTTP over the internet. This will involve opening/forwarding of ports on your firewall.
- SandsharkJan 02, 2017Sensei
What type of backup, manual or via some backup program? For manual backups, HTTP or FTP is an option. If by backup software that can't use either of those, you might want to look at ZeroTier (do a search of the forum) or another VPN solution.
- Coolfeather2Jan 09, 2017Aspirant
Both FTP and HTTP are not secure, I am manually backing up
- StephenBJan 09, 2017Guru - Experienced User
The NAS does support FTPS connections from an FTP client (and there is a setting to mandate FTPS) - so you can make that secure.
ZeroTier, OpenVPN and OwnCloud are all possibilities for remote access.
