landungsbruecke
Dec 08, 2017Aspirant
ReadyNAS 312 cannot be accessed with LAN1+LAN2 at the same time after upgrade to FW 6.9.1
Dear community, we are running a ReadyNAS 312 connected to two networks (one via LAN1 with a fixed IP, and another via LAN2 with another fixed IP), using SMB. Until we upgraded to the current firmwa...
landungsbruecke
Dec 14, 2017Aspirant
I could fix the issue by indeed downgrading to my previous version 6.7.5 and the doing a OS reinstall. One thing to note might be that on eth0 we have a windows network, and on eth1 we have a OSX (Mac) network. We did a full backup before, though (but luckily did not need it).
So for me this points to some misconfiguration in the internal eth0/eth1 settings after the firmware upgrade from 6.7.5 to 6.9.1.
Marc_V
Dec 17, 2017NETGEAR Employee Retired
Hi @landunsbruecke
Please note that downgrading is not recommended.
And I don't think that this is an issue with the current firmware though as we have tested it with Windows and Mac OS and we do not get the same concern, perhaps a little more information from the logs could have helped us determine the cause of the problem and resolve it.
Regards
