GalacticaRaptor
May 11, 2016Aspirant
ReadyNAS 314 mount_block_root +1e9 but USB Recovery doesn't work
Just bought a refurbished ReadyNAS 314 from Amazon, and cannot seem to boot it up. When turning it on, it shows "Booting..." and then rather quickly displays "mount_block_root+1e9". The recommend...
- May 11, 2016
Curiously enough, the same drives worked. Seems like the USB Recovery Tool is broken. I attempted to boot the created USB Recovery drive on my PC, and nothing showed up. Repeated using the USB Recovery Tool to recreate the drive again, and each time testing to see if I was able to boot from the drive on my PC (you can tell when you get "Press any key to boot from USB" or similar, and a whole bunch of terminal output if you tap any key). When it is bootable, put that verified bootable drive in the front port on the NAS and the firmware flashing worked like a charm.
mdgm-ntgr
May 11, 2016NETGEAR Employee Retired
Try some different USB keys. Probably the one you tried is imcompatible.
GalacticaRaptor
