thranil1's avatar
thranil1
ReadyNas 316 drive swap failure
I had a drive fail this last week (dead as a doornail) for my RAID 5.1 configuration. All 6 bays are populated with 2TB WD red drives, and total used disk space was around 3 TB, so there was PLENTY of space left for handling the swap. I bought a new WD 2TB red HDD, powered down the RN, swapped the drives and turned it back on. It came up with a status saying that it was rebuilding the data (don't remember the exact words, sorry), and after about an hour, it started flashing "DEAD". I checked the RN admin web interface and it showed that all drives were red with an error at the top stating "Remove inactive volumes to use the disk. Disk #1,2,3,4,5,6".
So this is fun. At this point, I'm wondering if there's a way to get my data back or if I'm just stuck having to rebuild everything... which completely nullifies the whole point of having a RAID 5.1...
  • Thanks for the reply! My understanding was RAID 5.1 was RAID 5 with a hot spare. It's very possible that I'm misunderstanding. I've read through the logs, and while I see where the error is (in the kernel.log), I don't know what to do with it. I sent you link to the logs - I'm hoping you may see something in there that's meaningful to you?
  • StephenB's avatar
    Don't follow that advice - you will lose data if you do that,
    What do you mean by RAID 5.1?  Do you have 5x2TB RAID 5 with a hot spare?
    There is no redundancy during the swap.  So if one of the drives fails during the process, the volume can fail.
    RAID is not enough to keep your data safe - you need a backup plan to do that.  There are several other ways a RAID volume can fail.
    There might be, but we'd need to figure out what went wrong.  Keep the disk that you removed intact (leaving it as it is).
    Download the full log zip file.  If you need help analyzing it, you can upload it into cloud storage, and send me a private message (PM) with a download link using the envelope icon in the top right of the forum page.   Make sure the permissions allow anyone with the link to download it.
    Don't post the link publicly - there is some privacy leakage when you do that.
ProSupport for Business
